The ignition key on my race car (from a 1982 Ford Cortina) allows you to crank once, then the starter position is locked out until you key-off again. Pretty standard.makro wrote:Tell me more about this interlock?!?! I'm assuming some cars you have to turn the power off to restart the engine??Reverant wrote: Yeah, isn't it great that not all cars have the dreaded starter interlock?
Do they show on the TS dash? If they don't, they aren't working.James, I've managed to compile and flash the modified source with those bits set at startup, however the dash doesn't show that the fuel and spark cut is active. Are these indicators something that get's updated separately under normal operation when it's activated through the CANBus code or through another area of the code?
It doesn't really bother me, more so just so I know it's working as expected. As long as I can disable it and start the car, that's the main thing.
Thinking about it, don't set the flagbyte bits, instead
Code: Select all
datax1.shutdowncode = SHUTDOWN_CODE_ACTIVE | SHUTDOWN_CODESPK_ACTIVE;
