in the screenshot above, DLC is read from 1st receive buffer every time.makro wrote:So what did you change in your code gurov??
Code: Select all
DLC = MEGASQUIRT.CANRead(MCP_RXB0DLC);
Code: Select all
well, but that's the thing though...makro wrote:Ohhhhh yes... good pick up and innocent mistake!!
So every so often it would be reading the DLC from a different message in the other buffer. As the buffers don't get cleared after reading a message, you would occasionally see a larger DLC code which would be reading the 2nd or 3rd byte from the previous CAN message in the same buffer you're reading your new message from.
Makes sense I think.
i started looked at the rest of the code when the corruption migrated to output ports.makro wrote:If you had turned all other CAN features off in Megasquirt then I can see what you're saying... you should only be receiving one type of CANPWM message and IIRC that always has a 0 - 100 value in the first byte for me. However if you're using CANPWM8 then yeah you'll be seeing it in the eighth byte.
Is your CANPWM1 setup at all?? Because my MS3 is unconnected on my desk, I see guages from time to time flicker as I'm assuming there are some floating inputs affecting it (as they're all unconnected). If that flickering guage is actually linked to the load axis on another PWM, then maybe you're getting the dummy values from that flickering? Just a suggestion really... I'm probably barking up the wrong tree.
hey man, this s*** don't make sense to me either. it worked when reading from buf0, jacked when reading from buf1, cause dlc is read from buf0.makro wrote:Yeah I don't think that's how it works IMHO.
You are simply sending the MCP2515 the SPI read instruction and it's returning the data to you. The order of which of the different bytes of the buffer are being read is something the programmer gets to decide.
What SPI command are you sending to read the buffers? Is it one of the quick read commands??
Code: Select all
EID8=MEGASQUIRT.CANRead(MCP_RXB1EID8);
EID0=MEGASQUIRT.CANRead(MCP_RXB1EID0);
DLC =MEGASQUIRT.CANRead(MCP_RXB1DLC);
databuffer[0]=MEGASQUIRT.CANRead(MCP_RXB1D0);
databuffer[1]=MEGASQUIRT.CANRead(MCP_RXB1D1);
databuffer[2]=MEGASQUIRT.CANRead(MCP_RXB1D2);
Code: Select all
INT8U MCP_CAN::mcp2515_readRegister(const INT8U address)
INT8U ret;
MCP2515_SELECT();
spi_readwrite(MCP_READ);
spi_readwrite(address);
ret = spi_read();
MCP2515_UNSELECT();
return ret;
