I've followed the instructions in the source files and tools files and have CYGWIN loaded up ready to go with all of the packages under the devel tree. When I type 'make' in the source directory, I get the following output / error.
Matt@Matt-PC ~/ms3-source-1.3.2/ms3
$ make
/bin/echo "// setup for MS3" > opt.h
grep -v "^#[12345]" core.ini | sed 's/^#0//' > ms3.ini
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -O -fomit-frame-pointer -m9s12xg -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mxgate,--xgate-ramoffset -c xgate.s
Makefile:127: recipe for target 'xgate.o' failed
make: *** [xgate.o] Error 127
Does anybody know what this means?
C:/usr/bin is a valid dir and I can see all of the build executables in there.
Compiling source
Re: Compiling source
I seem to remember a problem I had once where Cygwin would silently fail to execute programs. It was a real pain.
What happens if you type in
c:/usr/bin/m68hc11-elf-gcc --version
That should return something like:
m68hc11-elf-gcc (GCC) 3.3.6-9s12x-20120502
Copyright (C) 2003 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If that's ok, then try the full command line for that compile step:
Just a shot in the dark, but I had some similar issues with build errors that made no sense.
The way I fixed my problem was to go back and install the 32 bit version of cygwin and the build tools. I had installed the 64 bit version for my Win7 laptop and it appeared that the compiler tools did not like 64 bit.
- Steve
- Steve
Steve Hauer
http://www.77e21.info
1977 BMW 320i with MAF, COP, IAC, Sequential fuel and spark, MS3 knock sensing
MS3 / MS3X / V3 mainboard, MS3 V1.5 a4
Thanks guys - I'll try those suggestions out and report back.
What's interesting is that I've also tried on my Ubuntu x64 virtual machine and I get a very similiar error.
The 64bit theory may have some merit.
James - no good....
Matt@Matt-PC /cygdrive/f/Matt's Stuff/_Project180SX/ms3-source-1.3.2/ms3
$ c:/usr/bin/m68hc11-elf-gcc --version
Nothing at all.
Nothing at all.
You're on the money Steve. As soon as I installed the 32bit version of Cygwin... instant success.shauer wrote:Just a shot in the dark, but I had some similar issues with build errors that made no sense.
- Steve
Thanks!!!
Double thanks! I was pulling my hair out too. Maybe because the tools are 32 bit so the don't want to work in 64 bit cygwin?makro wrote:As soon as I installed the 32bit version of Cygwin... instant success.
Thanks!!!
