hi i was wondering if it is possible to add the feature where when ac is engaged a programmable output can be grounded also to control a second fan or any other device for that matter??
thanks
secondary fan when ac is requested
Re: secondary fan when ac is requested
Yes, you can do it with the on/off outputs using a bitwise "AND" condition.
If you look at section 19.18 of the Megasquirt-3 TunerStudio reference manual, you'll find "Status7" and see that value 32 means AC on.
So, if you configure an output with
"status7" "And" 32
as the condition, then it should turn on when AC is active.
"status7" "And" 32
We are already using that output as a cooling fan.
So we want the fan to activate both when the coolant temp is high, as well as when the A/C activates.
The man behind MS Labs
it worked
reverant that is exactly what i did, im using 2 outputs going to the same relay and fan. 1 output is programmed to come on above a predetermined temp, then the status 7 james helped me with is on the same relay. then my primary cooling fan is on another output and relay.
that fan is also set to come on when ac is requested
Why waste 2 outputs for the same device when the code can do it with one output? Code that I've already written and that also has idle-up for the second fan as well.
im only using 1 extra output.
nitrous 1 is used for my radiator fan
idle is used to trigger ac fan at x temp and above y rpm
injector g is used to trigger ac fan when ac is requested.
radiator fan is set in config to turn on with ac request
ye i could use idle and used an or condition for ac but then ac fan would spin before car starts on a hot start.
