Low/Zero Oil Pressure Shutdown
Is it possible for me or anyone to add this feature in case of a zero oil pressure condition? I will be running an oil pump that is driven by a cog belt and if it were to fly off, or the pump sucks air, I would like an automatic ignition shut down instead of relying on a pressure switch?
MS3Pro Ultimate
1994 Thunderbird SC
Fully Sequential, SVO Odd Fire V6
IGN-1A Coils - Brisk resistor plugs
12 magnet IW wheel (troubleshooting Holley 554-124)
Ford factory half-moon hall effect cam sensor
Using Dual Wheel non-missing tooth crank wheel strategy
Twin Turbo / TH400
1994 Thunderbird SC
Twin Turbo / TH400
Re: Low/Zero Oil Pressure Shutdown
The latest MS3 has an oil pressure warning light output, although it's not intended for automatic shutdown use.
Is it a strong enough signal to use a relay to shut off the ECU's power?Matt Cramer wrote:The latest MS3 has an oil pressure warning light output, although it's not intended for automatic shutdown use.
MS3Pro Ultimate
1994 Thunderbird SC
Twin Turbo / TH400
1994 Thunderbird SC
Twin Turbo / TH400
