Lean Burn and target AFR
During cruising I would like to go past the set limit of 20:1 afr in the AFR target tables. I do want to still use the target tables if possible. How can I make this possible configuration?
Re: Lean Burn and target AFR
I don't recall ever seeing a wide band that can measure over 20:1 AFR. Would be hard to target something you can't measure.
Cheers Luke
Cheers Luke
The LM-1/LC-1 etc can measure up to 80:1, and of course % O2 in the air (ie 20.9%).slow_hemi6 wrote:I don't recall ever seeing a wide band that can measure over 20:1 AFR. Would be hard to target something you can't measure.
The man behind MS Labs
