altarnate fuel setting boost per gear
I am wondering what does the code do with the target tables when boost by gear is selected I am trying to set up the setting between my 2 fuel and targets boost depending on the fuel. I am using boost by gear but can not find where to switch the boost targets for the gear depending on the fuel.
Re: altarnate fuel setting boost per gear
To clarify my question does boost per gear parameter can be change with the alternate fuel switch settings?
If not I think it should be added in the manual or in a comment in the ini like it is done in other things.
You can't do both at the same time.
Got it.
This got me thinking James what do you think instead of having the gear targets in the current window we make the Y axis of the target tables switch?
