GM 7X support for 4 cylinder engines
Would it be possible to add 4 cylinder engine support to the GM 7X decoder? I am in the process of installing an MS3-Pro on a 2005 2.2L Ecotec which uses the 7X for CKP and I am getting a "wrong cylinder count" config error. I have both composite and tooth logs if needed.
Jeff
Jeff
Support the developers!
Re: GM 7X support for 4 cylinder engines
Please post your MSQ, 4cyl should be allowed in the current firmware.
Sorry I meant to do this sooner....
Jeff
Jeff
Any luck with this?
Just tried it and I get the config error too. Investigating.prof315 wrote:Any luck with this?
There was no data for 4-cyl sequential with GM7X, so I've made up the triggers.
I'll send you a test code, but you need to strobe it and the code may need tweaking. The phase might be flipped too.
EDIT: Sent.
EDIT: Sent.
the 7x sequential for the 6 cylinder works excellent, james pulled some of his magic and has never missed a beat.
James if any of the new changes may effect the 6 cylinder just let me know i will load up the test code and verify
Got it, thanks James! I will report back as soon as I can.
There shouldn't be any impact. In pseudo-code form I've done this:JAM wrote:the 7x sequential for the 6 cylinder works excellent, james pulled some of his magic and has never missed a beat.
Was:
Code: Select all
if (num_cyl == 4) {
set config error
} else if (num_cyl == 6) {
set up 6 triggers
Code: Select all
if (num_cyl == 4) {
set up 4 triggers
set up 6 triggers
Thats great, just keep me posted. Thanks for all the effort making all the decoders for so many applications.
X2!JAM wrote: Thanks for all the effort making all the decoders for so many applications.
Success! It needs a trigger angle of 0* for the correct timing but the engine fired on the first try
Thanks James!!!!!
Jeff
Thanks James!!!!!
Jeff
Was the phasing for COP correct too?
I couldn't tell you as I am using the factory Ion Sense wasted spark ignition. Is there a way to test phasing with the sequential injection?
If you are able to strobe the cam pulley from an injector wire, then maybe?
