Hi, I have question.
In vvt I have 2 (or 4 sensors). is it possible insert the choice between vvt1 and vvt2 for cam input? this choice is used to test which configuration is best for the sync in the crancking.
In s54 I have used vvt1, intake. But I realized that my choice is wrong, because intake have 6 tooth and I have always sync in pms, both in the exhaust phase and the compression phase.
In vvt2 I have 8 tooth and I think is the correct choice. Now I invert the wire, no problem, but if in the future it is possible select vvt1 or vvt2 via software, this can facilitate the choices.
cam input in vvt
Re: cam input in vvt
It isn't an easy change to make.
The composite log you posted (VVT1) looked just fine for "poll level" - what problems are you seeing?
I attach the composite.
You can see in any case, I have sensor cam in any case at 11-12 cranck tooth (phase compression or phase exhaust)... same time the engine not start in sequential. In semisequential start very well, but in sequential no.
