CAN questions (was: MS3 pre-1.4 alpha 8 released)
Hello,
i have a Setting error and don't know how to handle this one...
Can anyone help?
Can anyone help?
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Re: MS3 pre-1.4 alpha 8 released
Looks like your CAN transceiver is broken.
How does the MS can check this?
This Error is coming up when i try to send Can data to the MS.
Broadcasting with the MS is working normally.
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
If the CAN system fails to initialise within a reasonable period of time, the code decides that it must be broken and flags that error.
The only times I've seen it are when a customer has damaged the MS3 card and broken the processor. Sometimes the CAN chip gets broken too.
Code: Select all
/* wait for synch to bus */
ix = 0;
while ((!(CAN0CTL0 & 0x10)) && (ix < 0xfffe)) {
ix++;
asm("nop");
asm("nop");
asm("nop");
asm("nop");
if (ix == 0xfffe) { // normal behaviour ~38
// CAN broken
conf_err = 190;
Ah okay,
I think mine is okay because Broadcasting work without any error.
The only Problem is that i receive strange data.
I'm trying to figure out why i get this Data.I think the Problem is my test System.
However it's not possible for me to send Data to the MS.
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
The setting error only occurs when i send packages with my can device and Switch the MS on while i'm sending continuously packages.
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
That's probably the problem, the CAN module likely needs to see a clear bus to be able to initialise. You'd have to read the Freescale datasheet for the part (MC9S12XEP100) to be sure.Alfagta wrote:The setting error only occurs when i send packages with my can device and Switch the MS on while i'm sending continuously packages.
On a microsquirt module, I've also seen the MCP2551 being placed 180* from the factory!
The man behind MS Labs
That's not good! But it's good to know that this has been seen. However, in this case it can't be the issue since there has been some transmission which would not happen with a reversed chip.Reverant wrote:On a microsquirt module, I've also seen the MCP2551 being placed 180* from the factory!
Hello,
the tranmission to the MS is working now.
Now it's time for the receive from the MS.
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Hello,
can communication works fine now.
But i have another question, in the "Can Receiving" i can choose 24 Can ADC Inputs.
But it is not possible to set 24 Can ADC Inputs because there are only 16 fields.
So why do we have 24 ADC Inputs?
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
You can fetch data into them using the "CAN polling" system.Alfagta wrote:So why do we have 24 ADC Inputs?
Yes i know but this is the "old" Megasquirt Can Protocol or isn't it?jsmcortina wrote: You can fetch data into them using the "CAN polling" system.
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Yes, but you can use them at the same time.Alfagta wrote:Yes i know but this is the "old" Megasquirt Can Protocol or isn't it?jsmcortina wrote: You can fetch data into them using the "CAN polling" system.
And if i will use them i had to implement the Original Megasquirt Can Protocol which i don't fully understand right now.
Because the alignment of the Data in the Register's are not the same as standart Can Protocol 2.0A/B
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
If you do want to do that, take a look at the protocol document in http://www.msextra.com/doc/pdfAlfagta wrote:And if i will use them i had to implement the Original Megasquirt Can Protocol which i don't fully understand right now.
I can Request Data from the MS now.
I also can parse an request from the MS.
But i don't relly know how the Response for an MS Request has to Looks like.
For ADC Polling i get the following Message from the MS:
From id:0
To id:5
Var Block:7
Var Offset:2
So how has the Response to be?
From id:0
To id:5
Var Block:7
Var Offset:2
Alfa 156 GTA
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Did you see the Teensy or Arduino posts in the expansion boards section of this forum? They contain both protocols, MS and standard. I suggest to take a look at https://github.com/merkur2k/MSCan_Gauge ... /README.md
that is how I learned it...
Race car building documentation: www.kessel.tk (nice pics but only german laguage so far...)
Did the PDF document not explain it clearly enough?
That would do it...Reverant wrote:On a microsquirt module, I've also seen the MCP2551 being placed 180* from the factory!
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
