Toyota 3SGE Beams VVTi code
AbatelliCristian
Re: Toyota 3SGE Beams VVTi code
Post by AbatelliCristian »
This is my "standard" configuration for max9926
R25 IS ONLY FOR HALL SENSOR. NOT INSTALL IN VR SENSOR
I work well with this value and configuration.
mr2.3sge
Post by mr2.3sge »
I didn't put the R27 and R28 resistors. Should I put them? I'm just working with 4.7kOhm shunt and with 470pF.
I'll try to put a 330pF capacitor on Monday
AbatelliCristian
I do not know the ms3module ....
I think r27 r28 and capacitor is already installed in your card, but please contact Matt for clarification
Test only 4,7k shunt resistor in cranck sensor and 1k shunt sensor in cam sensor without insert capacitor.
mr2.3sge
Post by mr2.3sge »
Clean signal with 1k shunt resistor on CMP and 4.7k shunt resistor on CKP.
Wideband helped me a lot to have a good idle (running semi-sequential and Wasted COP). I'll try fully-sequential tomorrow...
AbatelliCristian
:) very good
mr2.3sge
Post by mr2.3sge »
Need phase change on 2JZ VVTi 4Cyl decoder. The engine didn't start with fully sequential settings.
Many tks for your help AbatelliCristian ;)
pimp4lyphe
Post by pimp4lyphe »
mr2.3sge wrote:Need phase change on 2JZ VVTi 4Cyl decoder. The engine didn't start with fully sequential settings.
Did you try 575° as trigger angle?
ragepower
Post by ragepower »
That only apply to tooth wheel. He is using a specific trigger wheel, for 2jz.
pimp4lyphe
Yeah my bad.
ragepower
Post by ragepower »
pimp4lyphe wrote:Yeah my bad.
No problem, we are learning every day
mr2.3sge
Post by mr2.3sge »
Hi James,
I'm still waiting for changes on 2JZ VVTi 4Cyl decoder.
Many Thanks
Changed for the next dev release.
Now available.
mr2.3sge
Post by mr2.3sge »
Now available.
It works perfectly ;)
Many Tks.
jasaircraft
Post by jasaircraft »
great support!
Marc D
Post by Marc D »
Will the 2JZ VVTi 4-cylinder mode also work for the 3S-GE black top BEAMS with dual VVTi? The wheel patterns and cam sensors are the same with the exception of the exhaust cam and the same 4-1 pattern on the exhaust cam shaft.
Thanks!
So long as the crank and intake cam patterns are the same, you will get full RPM-sync. A regular 4-1 pattern on the other cam ought to work ok by enabling a second cam input and selecting 4 teeth.
Marc D
Post by Marc D »
Thanks for the reply.
I just checked the settings regarding the VVTi. I was able to select the number of VVTi solenoids to be controlled, but the number of teeth on cam 2 was not selectable.
Marc D wrote:Thanks for the reply.
I checked the code. For 4cyl is it always assuming that the cam teeth fall on a 4 tooth pattern.
Marc D
Post by Marc D »
Perfect, that helps a lot. Thanks!
