Toyota 3SGE Beams VVTi code
Re: Toyota 3SGE Beams VVTi code
This is my "standard" configuration for max9926
R25 IS ONLY FOR HALL SENSOR. NOT INSTALL IN VR SENSOR
I work well with this value and configuration.
I didn't put the R27 and R28 resistors. Should I put them? I'm just working with 4.7kOhm shunt and with 470pF.
I'll try to put a 330pF capacitor on Monday
I do not know the ms3module ....
I think r27 r28 and capacitor is already installed in your card, but please contact Matt for clarification
Test only 4,7k shunt resistor in cranck sensor and 1k shunt sensor in cam sensor without insert capacitor.
Clean signal with 1k shunt resistor on CMP and 4.7k shunt resistor on CKP.
Wideband helped me a lot to have a good idle (running semi-sequential and Wasted COP). I'll try fully-sequential tomorrow...
very good
Need phase change on 2JZ VVTi 4Cyl decoder. The engine didn't start with fully sequential settings.
Many tks for your help AbatelliCristian ;)
Did you try 575° as trigger angle?mr2.3sge wrote:Need phase change on 2JZ VVTi 4Cyl decoder. The engine didn't start with fully sequential settings.
That only apply to tooth wheel. He is using a specific trigger wheel, for 2jz.pimp4lyphe wrote:Did you try 575° as trigger angle?mr2.3sge wrote:Need phase change on 2JZ VVTi 4Cyl decoder. The engine didn't start with fully sequential settings.
Yeah my bad.
No problem, we are learning every daypimp4lyphe wrote:Yeah my bad.
Hi James,
I'm still waiting for changes on 2JZ VVTi 4Cyl decoder.
Many Thanks
Many Thanks
Changed for the next dev release.
Now available.
It works perfectly ;)Now available.
Many Tks.
great support!
Will the 2JZ VVTi 4-cylinder mode also work for the 3S-GE black top BEAMS with dual VVTi? The wheel patterns and cam sensors are the same with the exception of the exhaust cam and the same 4-1 pattern on the exhaust cam shaft.
Thanks!
Thanks!
So long as the crank and intake cam patterns are the same, you will get full RPM-sync. A regular 4-1 pattern on the other cam ought to work ok by enabling a second cam input and selecting 4 teeth.
Thanks for the reply.
I just checked the settings regarding the VVTi. I was able to select the number of VVTi solenoids to be controlled, but the number of teeth on cam 2 was not selectable.
I checked the code. For 4cyl is it always assuming that the cam teeth fall on a 4 tooth pattern.Marc D wrote:Thanks for the reply.
Perfect, that helps a lot. Thanks!
