Hi all,
Would it be possible for you guys to support logging more than 64 byte records?
I need to log a lot of performance data, and i hit the 64 byte limit before i fit everything in
Thanks.
Request - Log more than 64 bytes?
Re: Request - Log more than 64 bytes?
I implemented a 128 byte format last week. TunerStudio doesn't support it at this time though.
128 bytes should be plenty, thanks for that James
James, can we expect to see this in the 1.4 beta or release candidate, or is this a 1.5 feature?
This is a 1.5 feature. As it isn't presently supported by TunerStudio I cannot fully test it.
Once the support is there in TunerStudio and I can test it, I can consider whether to backport to 1.4. It wasn't as big a change as I'd thought, but there is no point in having knowingly untested features in 1.4 as it heads towards "release".
