I build an ms3-pro based pnp for 185st celica. In the meantime I use 1.3.3 firmware.
In A/C Idle-UP settings, in drop-down menu there are all the inputs to crank the idle up except DI3 (Digital input/switched 3)
I don't see any reason this one is not there. Could this be added in 1.4... firmware?
Thank you.
A/C Idle-UP. A tiny feature request
Re: A/C Idle-UP. A tiny feature request
We will consider it... if not for 1.4 then for 1.4.1 or 1.5.
Oh, thanks a lot. This could wait. Redoing my pnp to suit the feature would mean a lot of wiring work. I thought, it was just accidentally forgotten to be added to the earlier firmware releases.muythaibxr wrote:We will consider it... if not for 1.4 then for 1.4.1 or 1.5.
