I would like to use fuel pressure while cranking.
Not sure if this is already enabled. With the Fuel Pressure curve.
On the Roush LPI (liquid propane injection) vehicles. The A1000 fuel pump and regulator are installed in the Propane tank.
The regulator is referenced to tank pressure. It's set for around 40 psi above tank pressure.
Thank you
can fuel pressure be used while cranking for propane
33 psi boost on lpg
