Innovate MTX-D EGT Gauge support.
I already have an MTX-L Wideband connected serially to a TinyIOx, and was wanting to know if I can connect the EGT gauge to the existing serial chain, and import that data via canbus too?
Re: Innovate MTX-D EGT Gauge support.
At this time only the AFR data is supported.
Is there anything I can do to assist in this feature to be added?
don,t you think you would be happier using the CAN EGT from diyautotune
an use your Android phone with shadowdash
you can design your own screen in tunerstudio to display the channels
and import it in shadow dash
you have a 4 cylinder car ?
maybe use the remaining egt channels for something else
air, water,oil enz?
air, water,oil enz?
Well, I also do have something coming up in the near future that will add EGT support for the TinyIOx (up to 4 inputs) along with other I/Os. More will be announced when it is closer to a release.
But the DIYAutotune CAN-EGT is definitely something to look into and is available now. It is also fully supported by the MS3 and TunerStudio.
I plan on using a Can-EGT, but I also wanted a full-time gauge. The Can-EGT doesn't come with a dedicated gauge.
if you are dead set on a 52 mm gauge
there are some things happening!
http://www.msextra.com/forums/viewtopic ... 67&t=56565
