Fiat 500 abarth CAN dashboard
Hi guys,
I have install ms3 on 500 abarth tjet.
I have tried to enable broadcast Can fiat/lancia, but the dashboard no work...
Do you have experience with fiat dashboard?
Best Regards
Cristian
Best Regards
Cristian
Re: Fiat 500 abarth CAN dashboard
Parallel installation? Is this a street car?
The man behind MS Labs
No parallel install with stock ecu. Only MS. The car is street and it takes part in some races time attack
Hi Jamse,
I have used sniffer for CAN fiat 500 abarth
I hope is helpful.
Attach Photo
DATA6 byte for RPM
bitrate controll 500kbps
I hope is helpful.
Attach Photo
DATA6 byte for RPM
Are you sure that's only data 6? That doesn't seem right and the zip file looks like it might be data 5,6,7 (or at least 2 of those). It would make a lot more sense to have at least 2 bytes for RPM. Also, what RPM does that represent?
Hi Jean,
this is the first test. I have problem with sniffer software. it Is very slow when I trasmit the data. Data6 is certain. If I set 0 at data6=0 tachometer no move. Also I would expect 2 bytes.
Tomorrow I make new test with other pc. I hope I resolve the software problem.
Best Regards
Cristian
Best Regards
Cristian
Hi guys,
today I have re-analyzed the CAN
This is the results:
ID A18A001x
DATA2 FF = light water
DATA2 90 = light check engine
DATA7 FF = light change oil
DATA1 FF = light for diesel engine
DATA6 = RPM gauge:
1F = 1000 rpm
3F = 2000 rpm
5D = 3000 rpm
BA = 6000 rpm
Data3 = CLT gauge:
60 = 70°c
65= 80°c
6E= 90°c
9c=100°c
9F=110°c
A2=120°C
ID18A006x
DATA2 = VSS (not have scale at the moment).
I hope it is possible to use these data with MS
Best regards
Cristian
ID A18A001x
DATA6 = RPM gauge:
1F = 1000 rpm
3F = 2000 rpm
5D = 3000 rpm
BA = 6000 rpm
Data3 = CLT gauge:
60 = 70°c
65= 80°c
6E= 90°c
9c=100°c
9F=110°c
A2=120°C
ID18A006x
Best regards
Cristian
news for it?
Interesting to see this work as there are a lot of this cars around here, can and dbw are the main things that not allow people to upgrade to a fully programmable ecu... Fixing can will be great...
Enrico
Opel/Vauxhall Corsa GSi MS2
Subaru v4 EJ20 MS3
Subaru v4 EJ20 MS3
I have resolved..... I read the brodcast MS from my module DBW and convert the data in 500 abarth format...
https://youtu.be/yhED_-xZs0w
