James / Phil
I had a bit of an idea and not sure if its worth implementing but here goes...
In your logging screen you can see the crank and cam teeth, how about somehow including coil A and injector A trigger points (if you can output it from the MS3) in conjunction with the crank/cam to aid in troubleshooting and setting up.
MS3 / Tunerstudio logger idea
Re: MS3 / Tunerstudio logger idea
The firmware has an "Engine logger" that does similar to that. You need to have the registered version of TunerStudio to be able to use it.
