MS3 pre-1.4 beta 11 released
Re: MS3 pre-1.4 beta 11 released
Sooo, just to get this straight.... is CAN working ok in this release or not?
Toyota Celica GT4/Alltrac with 5S-GTE stroker (2.2L I4 turbo, high CR) on E85 w/FlexFuel.
MS3 + MS3X + KnockBoard + RTC + BT + DIY CAN-IO-Board + DIY CAN Digital Dash.
For me everything is working as expected.MWPau wrote:Sooo, just to get this straight.... is CAN working ok in this release or not?
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Yes it is. So if you have issues, this is not related to this firmware release but something else.MWPau wrote:Sooo, just to get this straight.... is CAN working ok in this release or not?
I've just retested and after the repair to my IO-x, my EGTs are working fine over CAN again.
so as with 1.4.10 I have the same 3 step bug . it is reversed . works fine on 1.4.3 when its off ecu says its on and limits motor here is a log for both and my current 1.4.11 msq
just to be clear with the 3 step switch off ecu sees it as on
with 3 step switch on ecu sees it as off
jsmcortina wrote:I concurr - the problem here is that the commands for real time clock comms are hardcoded in TS. I need to change the address that is being sent but I cannot. I've put in a support request to Phil to get this setting expose so I can change it in the ini file.AbatelliCristian wrote:sorry, other problem....
real time clock, no work.
That also explains why you can't set the time from the GUI anymore.
(well, you actually CAN, but it sets something like Feb 12 15745, which becomes Jan1 1970 or something by default)
That also explains why you can't set the time from the GUI anymore.[/quote]piledriver wrote:I concurr - the problem here is that the commands for real time clock comms are hardcoded in TS. I need to change the address that is being sent but I cannot. I've put in a support request to Phil to get this setting expose so I can change it in the ini file.
It looks like I'm going to have to roll this change back as it cannot be addressed in TS in the short term.
In both datalogs I can see the 3-step input switching on and off.525gte wrote:so as with 1.4.10 I have the same 3 step bug . it is reversed . works fine on 1.4.3 when its off ecu says its on
You have it wired to "Digital Switched 12V In" - this input is supposed to activate when you apply 12V. i.e. the 3-step should be active when you apply 12V.
Previously this was broken and working backwards. There was a change for pre-1.4 alpha8 to make this work as designed.
Code: Select all
2014-11-16 JSM
Respect Nitrous +12V polarity. **Beware changed behaviour**
ok I was unaware of the change . I have been on a earlier firmware for awhile ill take a look at the switch polarity this weekend thanksjsmcortina wrote:In both datalogs I can see the 3-step input switching on and off.525gte wrote:so as with 1.4.10 I have the same 3 step bug . it is reversed . works fine on 1.4.3 when its off ecu says its on
Previously this was broken and working backwards. There was a change for pre-1.4 alpha8 to make this work as designed.Check you wiring.Code: Select all
2014-11-16 JSM Respect Nitrous +12V polarity. **Beware changed behaviour**
