Hello,
is it needed to set Can Master enable to "enabled" when i want request data from the ms?
Or can i leave it disabled?
I have tested it and i also get an answear when i set it to disabled.
But ist that as it should work?
I have attached a can analyzer log.
Master enabled is at "diasbled" all the time.
The first few (0-25) entries are with the ms and the analyzer connected.
There i always get my request with false data.
And also the answear isn't correct.
Then i have disconnected the ms from the can. Entries 26-37.
As you can see the Request is send correct at this time.
After that i connected the ms back on the can bus.
Entries 38-56.
Request stays correct. And also the answear is correct now.
I don't now why i get a corrupt request when i startup everything when the ms is connected.
When i startup with the ms disconnected the request is okay from the first time on.
Any ideas what is going on there?
Thanks in advance.
Request Can Data
Request Can Data
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
