Options for staged injection fueling
Just thinking about my two projects and a project I help with in town. I'm picking up an egt box and will be logging egt per cyclinder under boost. Both my projects and the other are running staged injection with separate fuel's for the needed octane. Would it be possible with the next Pre-1.x code to be able to use the all the available injector outputs and assign them specific injectors? With my 6 cylinder that means I could run sequential staged and use an injector trim table to dial in cylinders, and my LS project I could wire them 2 injectors per driver and have a better chance of dialing in fuel over adding to all 4 and so on
My other day dream thought was to just wire them all primarily sequential, and relay swap using programmable outputs, meaning I could trigger the secondarys at 135kpa and trigger off the primary's at say 137kpa. That spot would be rich but it's so brief and Im hardly there it wouldn't matter
Re: Options for staged injection fueling
If you're asking for what I'm thinking you're asking. That's a pretty major change to the way we work today, so it's not going into 1.4 pre anything. I'll add it to the list for consideration/discussion in 1.5.
I understand about the code change, and was hinting towards 1.5
Having options for staged sequential injection would really help dial in a motor based on egt's and some possible stange stsging issues my buddy is having
Thankyou Ken
Thankyou Ken
Can you try to explain what you're asking for in a little more detail though? I'm not sure I'm understanding properly.nathaninwa wrote:I understand about the code change, and was hinting towards 1.5
Thankyou Ken
Being able to assign injector drivers to certain injectors to create a sequential staged injection setup. My 2j for instance will soon be tuned with egt probes on each cylinder. Currently we can only trim batch fired injectors, so for whatever reason lets say 6 is running is lean, I have to had fuel to 4-5-6 to bring down 6 temps, which will lean out the front cylinders. No way to really dial in fuel using the I/J outputs only. And my LS will have 4 injectors per driver when staged over from pump to 116 octane. Now the LS engine will not stage fully like the 2j, but 50/50 creating 104 octane, so yes I can add more pump, at the sake of reducing octane in that cylinder. If on the LS we can wire 2 injectors per driver that would be better than all 4
OK, I think I get it.
is it an idea to use V12 2 stroke setting on your 6 cylinder ?
that give,s you 12 injector outputs with trim tables
and then switch them with relays ?
