Following on from the above, but oddly independently, we've had some users (off forum) reporting inconsistent AFRs on each restart.
This appears to apply only to users with baro setting to "Initial MAP Reading" and is more apparent on installs with large injectors and a low idle pulsewidth.
We've not fully got to the bottom of this yet, but it _appears_ that in some cases that initial MAP reading is inaccurate giving a false "Barometer" reading. This then has an effect on fuelling.
That feeds in to the change discussed above where Barometer had an impact on fuel even when the baro correction curve was set to all 100s. (Beta 14 released last week disables that calculation and sets the defaults baro correction to "Off" )
I'm very keen to receive feedback from experienced users on stable installs that have "Initial MAP Reading" enabled.
a. With your existing tune and firmware please look at "Barometer" from start to start and see if it makes sense. Please datalog and post them here.
b. Compare with beta14 and "Old baro calc" set to "On"
c. Compare with beta14plus (below) and "Old baro calc" set to "On". Also observe dash gauge "Sensor 15".
This "plus" firmware has a small tweak so that baro is sampled twice and startup and the highest value used. "Sensor 15" contains the value that _would_ have been used.
The beta14plus firmware can be found here:
http://www.msextra.com/downloads/dev/ms ... ta-14plus/
Inherently the "Initial MAP Reading" concept is imperfect as there's always a risk that it will read engine vaccum instead of atmospheric pressure. However, it has been there since MS1 and we haven't removed it. If you really want baro correction then a second 1bar sensor should be used.
