Hi all,
When i enter a track-day or similar i manually disable overrun fuel-cut to help with combustion chamber cooling.
Can this be added as a MS3 option?
Something like: If avg load over the last XXsec is over XX%, disable overrun fuel-cut.
Thanks.
Disable overrun fuel-cut during high-load periods?
Re: Disable overrun fuel-cut during high-load periods?
I would think running air through the combustion chambers would be more effective cooling than a rich mixture.
Just passing air VS air+liquid... its pretty obvious which one cools better.
Running rich on overrun is a pretty common method of aiding in chamber cooling.
That would only work if you also did a spark cut.
Or ran it so rich it wouldn't ignite, but that creates it's own set of problems.
