MS3 pre-1.4 beta 15 released
Post by jsmcortina »
To announce the release of “MS3 Pre 1.4 beta 15″
ETA on this 1.4.x code becoming release is 2 months.
Who should use this code?
Experienced users wanting to test the new features.
Who should not use this code?
New or casual users – please use the current release code instead – see the Downloads page linked above.
Main changes since pre-1.4 beta 14
Bug fixes:
Fix MS3-Pro port names for EGT in.
Add CANin/out to datalog.
Bitmask BaroOption.
Make ONLY boost bias 1 used even when switching or blending.
New / changed features:
Re-sample baro on startup for "initial MAP reading" case and use highest.
Tweak initial baro calc.
Minor / internal:
Remove Coyote debug data.
Known bugs
The firmware zip is available from:
http://www.msextra.com/downloads/dev/ms3/1-4/beta-15/
Upgrading users are advised to enable the “old baro calc” for backwards compatability.
Some of the ini changes will result in harmless warnings when loading MSQs from 1.3.x
Users upgrading from 1.2.x or earlier codes need to pay more attention.
TunerStudio 2.6.x is REQUIRED.
E30_Driv3r
Re: MS3 pre-1.4 beta 15 released
Post by E30_Driv3r »
Hey James, Just loaded this firmware for the CL boost "fix". Would be awesome if you took a peek at my msq/logs to figure out what is going on.
See: http://www.msextra.com/forums/viewtopic ... 40#p439932
nathaninwa
Post by nathaninwa »
How did I miss this! I'll load up tomorrow and give it a run
AbatelliCristian
Post by AbatelliCristian »
generic sensor no work when rpm > 0..
I have tried with 60-2 and SR20 mode... same problem.
attach log
Something weird in that log for sure, please post your MSQ.
AbatelliCristian
Hi James, I attach 2 msq
1- 60-2 generic
2- SR20 installation.
all msq have same problem
Regards
Cristian
nathaninwa
Boost bias tables problem solved
AbatelliCristian
I have tried SR20 in wasted cop mode, but the car have big misfire. No lost sync. In coil on plug is all OK the car RUN
AbatelliCristian wrote:Hi James, I attach 2 msq
1- 60-2 generic
You've enabled "Knock debug" and it is storing the knock information to the "Sensors" variables per design.
AbatelliCristian
Ah... Thanks.... I check...
Best Regards
Cristian
ashford
Post by ashford »
im at a point where i have recovered enough to drive a stick car again. i plan on testing this out this weekend on the coyote. is there anything in particular you would like me to test/look for.
i have one question though. somewhere between initial test code and beta14 #of cam teeth became ungreyed and was always set to 1, should i try out inputting 7 in these boxes since the coyote has 7 teeth?
would this setting affect the way pid loop works? that might explain why pid changed on me for beta 14.
