For e100 in cold weather it's important to have more advance on cranking, it help a lot on temperatures below 20 degrees.
The request is for create a little table contain 5 points of CLT vs Cranking advance.
thanks!
Request - Cranking advance table vs CLT
Re: Request - Cranking advance table vs CLT
its already in the code 1.3.4 under ignition tab called cold advance
No, the OP is talking about cranking advance (when RPM is less than "Cranking RPM" parameter). The cranking advance is a fixed parameter under Ignition settings.esso wrote:its already in the code 1.3.4 under ignition tab called cold advance
I agree that this would be nice to have.
Sam
