Request - Cranking advance table vs CLT
Magovit
Post by Magovit »
For e100 in cold weather it's important to have more advance on cranking, it help a lot on temperatures below 20 degrees.
The request is for create a little table contain 5 points of CLT vs Cranking advance.
thanks!
335i //M
esso
Re: Request - Cranking advance table vs CLT
Post by esso »
its already in the code 1.3.4 under ignition tab called cold advance
pit_celica
Post by pit_celica »
esso wrote:its already in the code 1.3.4 under ignition tab called cold advance
No, the OP is talking about cranking advance (when RPM is less than "Cranking RPM" parameter). The cranking advance is a fixed parameter under Ignition settings.
I agree that this would be nice to have.
Sam
