I'd like to have the Ignition Timing + Fuel compensation and Boost, by Gear strategies implemented, so the code would be top class !
And if possible in the Rev Limiter section to have the hysteresis be made possible to be lower than 100, best if can be set to 0
Thank you
Feature request : Timing+Fuel+Boost compensation by Gear
Re: Feature request : Timing+Fuel+Boost compensation by Gear
You can use the speed and gear sensors plus table blending to do this now.
Good news,Matt Cramer wrote:You can use the speed and gear sensors plus table blending to do this now.
Thank you
