Need help on very strange MS3 output port bug
I have been tracing down a really strange bug the last few days, but I cannot get my head around what is happening. I think it is firmware related.
I use LOOP 1 programmable output for airconditioning idle up, and LOOP 2 for spark table switching. Both LOOP 1 and LOOP 2 should be active when coolant is above 70 celsius, and when engine status is " 5" . So far so good.
Problem is that it doesn't work. Sometimes my airco idle up is stuck and won't go away, and sometimes it doesn't get triggered when it is supposed to.
Check out the short log. The engine is started, coolant is above 70 and engine status is " 5" : but no airco idle up. Also the spark table isn't switched back when engine status goes back to "1"
Could you guys have a quick look into this, because something is amiss here.
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Innovate LC1 wideband lambda sensor
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Re: Need help on very strange MS3 output port bug
I'll email you an updated ini file that includes "loop" in the datalog set.
Update: turns out the output ports, loops1,2,3 en airco up are all fine.
The problem is in the fact that the output ports don't seem to handle the "engine status" parameter very well. As soon as I changed this parameter to "Gammaenrich>107" everything works fine.
Another question: why is it not possible to trigger an output port on %ASE?
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
I think the problem is the "Engine Status" condition.
Try the "And" operator instead of the "=" Operator.
Best regards
Best regards
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
I thought there was a choice of <, >, or =
The AND is only between two separate conditions as I recall?
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Bitwise AND is available too. See the manual: http://www.msextra.com/doc/pdf/html/Meg ... 3-243.html
Update: "AND" and "egine status" also doesn't work. Looks like enginen status just won't work in the output ports.
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
sd1nl wrote:Update: "AND" and "egine status" also doesn't work. Looks like enginen status just won't work in the output ports.
Don't have a log, sorry. But trust me on this one.
Tge msq is basically the same as the one attached in the first post, just the = has been replaced by AND
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
That won't work. See this: http://www.msextra.com/forums/viewtopic ... 20#p444122sd1nl wrote:Tge msq is basically the same as the one attached in the first post, just the = has been replaced by AND
Read it. So am I correct in saying that I should enter the engine status in the treshold box aswell as in the hysteresis box?
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Yes if you want the condition to be when the masked bits are all '1' (on). Since this is likely the case, just put the same value in both boxes.
I'm sure that this is quite confusing for people who are not used to working with bit fields and masks. I hope the new 1.4 documentation will have some details on this because that is not something I would expect the average (or even experienced) user to know and understand. Even the information I linked to is probably not sufficient for the majority of users.
Would it be possible to trigger the output port on only one of the eight binary bits, in my case bit nr3 (ASE)
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
Yes, that's the purpose of bitwise AND.
Confusion all over here.jsmcortina wrote:Yes, that's the purpose of bitwise AND.
You mean I have to enter the engine status in binary form instead of decimal? Otherwise it is not possible to distinguish the ASE bit only.
Could you show me what I have to enter into the two fields to be able to trgger on the ASE on/off only?
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
I added an example to the Setting Up manual. See:
http://www.msextra.com/doc/pdf/html/Meg ... 4-123.html
Thank you for taking my suggestion to add more information on this to the manual (even if it wasn't what prompted you to add it). I think this should make it much clearer.jsmcortina wrote:I added an example to the Setting Up manual. See:
I don't know if this is an artifact from my browser but the 'ASE active' text straddles 2 cells in the table (I tried this in another browser and I see it in Firefox and Chrome on Win7).
Ok, this makes things clear to me. Thanks.jsmcortina wrote:I added an example to the Setting Up manual. See:
Rover Vitesse 3.5
MS3 full-sequential
36-1 triggerwheel
Direct coil control
MS3 full-sequential
36-1 triggerwheel
Direct coil control
It was a good suggestion.racingmini_mtl wrote:Thank you for taking my suggestion to add more information on this to the manual
I see that too. I've been testing an alternative method of generating HTML-ised version of the manuals, but it's not ready yet.I don't know if this is an artifact from my browser but the 'ASE active' text straddles 2 cells in the table
