IAC closed under boost request
Wondering if it would be possible to add the option to close the IAC over a certain TPS % ? Alot of the Vipers and some of the custom installs have the IAC vented to atmosphere so under boost this is a boost leak.
2000 Suzuki Hayabusa turbo MS3 beta testing Plug and Play standalone
http://interfacepnp.webs.com/
http://www.youtube.com/Busams
Re: IAC closed under boost request
in closed loop is possible
What type of valve? Stepped or Pwm? I wonder how well the valves will respond with such a pressure differential? I've always plumbed non check valve setups back to pre throttle body intake tract. The 7m and 1/2j motors use a check valve so they can be plumbed to atmosphere
