Feature request: MAP for phase with ITBs
The MAP signal can be used for detecting engine phase in 1-cylinder and V-twin applications. Is there any technical reason why that can't be extended to any configuration with individual runners and a MAP sensor behind the throttle blade in runner #1?
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
1974 Jensen-Healey
Re: Feature request: MAP for phase with ITBs
Assuming the MAP sensor was only used for phase in lieu of a cam sensor, then technically that could work. I'm not sure how useful it would be if you were hoping to get MAP data from it also? Better or worse.
Well, the engine I want this for is a Lotus 907, and runners 1 and 4 already have taps in them. I was sort of guessing / hoping that Event Average and ITB mode combined would give a consistent enough signal when tapped from a single runner - but I have not attempted this. The MAP signal would look a lot like the one from a single cyl, if it works for a single, it should work on a 4...
Conversion is still in the planning stages. Most likely, I will end up hiding a MAF in the plumbing somewhere in front of the airbox and will have little use for the MAP signal, but just for the heck of it I thought I should try out ITB mode and see what I can get out of it. Not having to butcher up an old distributor for sync would reduce the hassle involved.
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
I think it would work quite well. Also, my limited exposure to single cylinder engines makes me believe that sampled at the correct time it would provide a usable MAP signal (at least one that you can tune by, that goes up and down with load up until your MAP switchpoint).
+1
would be a great feature!!!
