Feature Request: Modification of 36-2-2-2 wheel pattern
If possible, I would like to request that the 36-2-2-2 wheel pattern be modified to allow the trigger angle to be adjusted 50 degrees out vs 20 degrees. It was mentioned that the FFE 36-2-2-2 wheel kit for the RX8 fits the older rotary engines, but there is a 50 degree discrepancy between sensor locations. The sensor on the RX8 is 70 degrees after the single group of 2 missing teeth, where the earlier engines would be 20 degrees after the single group of 2 missing teeth.
