I found a bug in MS3 1.4.0, and think I found where it occurs in the source, too.
Symptom: datalogs of afrtgt1 just don't work, whether serial or SD. They start at 14.7 with the engine off, then instantly drop to 10.2 once the engine is running. However, it must be correctly calculated somewhere as "incorporate AFR target" doesn't result in a super-rich engine.
Cause: I believe the issue is typecasting differences between gl_afrtgt1 (which is used to determine the value and for the "incorporate AFR target" option) and outpc.afrtgt1 (which goes into the datalogs):
- ms3.h, line 1625: struct with afrtgt1, afrtgt2 as unsigned char (8 bit)
- ms3_vars.h, line 693: gl_afrtgt1, gl_afrtgt2 as int (16 bit)
- ms3_init.c, line 4714: outpc.afrtgt1, outpc.afrtgt2 initialized at 147 (8 bit)
- ms3_ego.c, lines 251-293: gl_afrtgt1, gl_afrtgt2 calculated by dummy variables tmp1, tmp2, which are unsigned int (16 bit)
- ms3_inj.c, lines 2847-2848: gl_afrtgt1, gl_afrtgt2 used for "incorporate AFR target" option
- ms3_ego.c, lines 246-247: outpc.afrtgt1, outpc.afrtgt2 (8 bit) set using gl_afrtgt1, gl_afrtgt2 (16 bit) --> bug!
This explains why "incorporate AFR target" works, why the initialization of the outpc variable works, and why it doesn't work once the engine is running.
Solution: I think it's as simple as changing ms3_ego.c, lines 246-247 from:
Code: Select all
outpc.afrtgt1 = gl_afrtgt1;
outpc.afrtgt2 = gl_afrtgt2;
Code: Select all
outpc.afrtgt1 = (unsigned char) gl_afrtgt1;
outpc.afrtgt2 = (unsigned char) gl_afrtgt2;
Thanks!
Take care,
Shad
