Feature Request
Feature Request
I am only new to Megasquirt so I hope I am not repeating a request for something that is not technically possible
Basic/Load Settings > Tacho Output Dialog box has options for
Speed
Can be set to one of two options:
• Normal – an output pulse is generated matching each cylinder event, i.e., 4 cylinder engines have 4
pulses per engine cycle;
• Half speed – output runs at half speed. This can enable a 4-cylinder tacho to be used on an 8-cylinder
engine.
Probably the most common conversion is to drop a V8 where a 6 cyl used to live.
leaving a 6 cyl Tacho in the dash
Could a third option be added to Speed - 3/4 speed - output runs at three quarters speed. This enables a 6-cylinder tacho to be used on an 8-cylinder engine.
Cheers
Gary Biggs
Speed
engine.
Cheers
Gary Biggs
MegaSquirted :-
Stroked 383 Chev in a Patrol (Ms2) Custom 36 -1 Wheel - Bank Fired injectors with wasted spark coil packs
250-2v Australian Ford 6cyl in a oz built 1966 Jeep CJ-6 (Ms3x) Full Sequential - Coil on Plug
302 Windsor V8 in a XJ Jeep (Ms3x) Full Sequential - MSD Ls3 Coil Pack
Re: Feature Request
That's already supported in the current firmware.
Re: Feature Request
Thanks James Glade to here that
Could you supply a link to the latest Version
Do I need to update Tunerstudio / MSExtra firmware loaded onto the MS-2 or both ?
Cheers
Gary
Cheers
Gary
MegaSquirted :-
Re: Feature Request
See that "Downloads" link? Click on it.
Re: Feature Request
I have upgraded Tunerstudio to the current version (2.6.19) and the MsII/Extra firmware to ver 3.4.0
Upon going to the Tacho dialog box the Speed dropdown box still has only 2 options Normal and Half
How do I get to Three Quarters speed ?
MegaSquirted :-
Re: Feature Request
You have posted in the MS3 development section. MS3 supports this, not MS2.
Re: Feature Request
Sorry James
Being new I was confused between Ms3 and Ver 3 of the motherboard
MegaSquirted :-
