Original code:
} else if ((ram5.fp_opt & 0x03) == 0x02) { // closed loop
long tmp1;
int tmp2;
unsigned char flags = PID_TYPE_B;
Suggested Code:
long tmp1;
long tmp2;
unsigned char flags = PID_TYPE_C;
Would these changes cause major problems? If not, I'd like to test this code. I have difficulty maintaining fuel pressure with the existing code, and my PID simulations show that Type C would be significantly more stable
Changing tmp2 from int to long, would this provide better resolution on the fuel pressure output, or is it just a waste of memory? The resolution on the existing code is quite poor, looking for increased control resolution.
Change request, Modification to Fuel Pressure control code
Re: Change request, Modification to Fuel Pressure control co
Type C might work better, but changing tmp2 to long won't give the output more resolution.
