Subaru STI 2 VVT
Re: Subaru STI 2 VVT
The second VVT input may work already as you say it has a regular tooth pattern.
AbatelliCristian
Post by AbatelliCristian »
Yes second VVT is 4 regolar tooth. First cam have 2 sensore in stock engine. one for vvt (always 4 tooth) and second for phase.
AbatelliCristian
HI James, I attach log for primary cam.
Hi have idea for semplify your work: At the moment in vvt setting page I can select only "main cam" for vvt1. if I have the opportunity to select other input, I can use the thirted VR sensor with regular tooth ( if you remembar subaru have 3 sensor on cam. One for phase and 2sensor with regular tooth for vvt).
AbatelliCristian
news for VVT subaru?
AbatelliCristian
News?
AbatelliCristian
I do not understand why I do not get answers.
No more than respond to my customers.
DeadStiff
Post by DeadStiff »
Might be best to start a new thread and link back to this one seeing as this thread is 6 months old.
MS3+X on 73 Karmann Ghia ignition only with LS2 truck coils firing in sequential, fuel next.
2333(103*70) Type 4 with DTM also sitting in living room just need exhaust.
juansh2385
Post by juansh2385 »
Probably the post has escape from James mind with all the things he has on the todo list.
I know is not ideal but if you are in a hurry is it not posible to modify the 4 tooth patter to grinding one tooth making it a 4-1 and match the pattern that is already supported?
Juan
AbatelliCristian
Is impossible. At the moment...
Did you ever try my suggestion of using the uneven cam as the main cam input and the regular cam as the second cam input?
I re-read the topic and didn't see an answer to that.
AbatelliCristian
Yes, I have tried, but if I use 36-2-2-2VVT the engine not start. Ther's problem with sync.
