As I'm going to a bigger turbo, and increasing boost I was planning on adding a way to adjust boost. I was going to use a Blend curve using a potentiometer to blend between tables 1 and 2. But now that I'm also planning on adding flex fuel is it possible to blend 3 different ways. IE have the pot select 5 different boost levels, and each of those gets adjusted by the flex blend too?
Is there already a way to do this?
3d boost blending
Re: 3d boost blending
Also, does boost by gear work when using flex blend too?
