Hi guys,
Today I tested roving idle on the Escort Cosworth .
I noticed two problems.
First problem: after the 'start-up, the roving idle kicks in after several seconds and then I find the engine at 4000 rpm (the tps I to 15% for als).
Second problem: the calculation speed of the roving seems too low and even if the rpm down and roving table I indicated 0, during wuarmup the engine stops.
at the moment, I enabled the dual Ve table based tps. This helps me after crancking not accelerate too engine
regards Cristian
roving idle, cranck and wuarmup
