MS3 pre-1.4.1 beta 4 released
Post by jsmcortina »
To announce the release of “MS3 Pre 1.4.1 beta 4”. This is hoped to be the final beta before 1.4.1 is released, please try it.
Who should use this code?
All users are encouraged to try this code.
Main changes since pre-1.4.1 beta 3 release
Bug fixes:
TEXTe0 loader workaround. Copy random_no from application.
Closed-loop boost channel 2 typo fix.
New / changed features:
Add CBR600RR even fire 4-cyl variant of RC51.
Minor / internal:
Tooltip updates.
Known bugs
The firmware zip is available from:
http://www.msextra.com/downloads/dev/ms ... -1/beta-4/
Upgrading users are advised to enable the “old baro calc” for backwards compatability.
Some of the ini changes will result in harmless warnings when loading MSQs from 1.3.x
Users upgrading from 1.2.x or earlier codes need to pay more attention.
TunerStudio 2.6.x is REQUIRED.
dontz125
Re: MS3 pre-1.4.1 beta 4 released
Post by dontz125 »
Will the CBR600 be added to the MS2 code? (MicroSquirt, motorcycle, *ahem* ... :lol: )
dontz125 wrote:Will the CBR600 be added to the MS2 code? (MicroSquirt, motorcycle, *ahem* ... :lol: )
I committed it to the MS2 code before adding it to MS3.
Has anyone tried out pre-1.4.1 beta 4 on their vehicle? Anything to report?
MWPau
Post by MWPau »
Loaded this arvo (moved up from 1.3.4), went for a 1hr drive, all good so far.
juansh2385
Post by juansh2385 »
James nothing bad to report all working good. I'm using the following features without problem (set up 4 cilinder 24-1 trigger at cam speed. sequential fuel and cop boost by gear , generic pwm for a water pump table switch for fuel,spark, boost. tach output, and fan control/aircondition control).
I also teste the code on a 4g63 engine and a couple v8.
Next Im going to try use the 2jz code for a 4 cilinders 2zz toyota engine and post results hopefully soon.
Post by Matt Cramer »
We've dynoed a Miata on this firmware and did not see any weirdness.
