CL idle crank to run taper on pre 1.4 beta10
Ive been using this on my 240sx for a year or more and I put it in my miata as well and open loop idle works good. Crank to run taper works as it should .I switched to CL idle today and now instead of tapering down from 65% to 32% over a time of 10 seconds...it immediately dumps off the idle to 32 as soon as it runs with no taper. Here is a log. Is this a known bug for this version of firmware and I'm just now discovering it ?
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Re: CL idle crank to run taper on pre 1.4 beta10
Yes it is a bug but I guess it doesn't matter. I flashed in 1.4.1beta1 and the problem is gone
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Why not 1.4.0 release? or the current beta?
I was under the impression there were some bugs in the current release and I already have the beta 1 version on my laptop because that was the bug fix at the time (a couple weeks ago) so I flashed that in just to test to see if that was the problem.I will likely go to the most current beta.
. Im also not totally sure it was a bug now. I had it happen once with this fw. I changed the cl delay to a little longer and it stopped. Not sure that has anything to do with it. What do u think James? I didn't check it on the stim.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
