I can not get he351ve can bus working changed baud rate to 250 changed boost to open loop so boost duty sent out of boost
tried broadcast interval 150, 50 and 70 ms
what's a good free can bus sniffer for arduino?
HE351VE turbo CAN broadcast in pre-1.5 alpha 4
33 psi boost on lpg
Re: MS3 pre-1.5 alpha 4 released
Glad you've tried it, but unfortunate that it isn't working yet.
I'd certainly like to know what's different about the data. If the baud rate is ok, then perhaps an error in the packet.
It would be worth starting a new topic for this - I'll split this one.
The current code looks like this:
Code: Select all
/* Typically the turbo wants 250k baud. (Ford application 500k?) */
if (ram5.can_bcast2 & CAN_BCAST2_HE351) {
unsigned int bv;
/* holset HE351VE VGT turbo and a wastegate
29bit CAN message 0x0cffc600
8 bytes
D0, D1 = 16 bit little endian value 0-1000 for position
D1 = 0x02
D2 = 0x01
D3 = 0xff
D4 = 0xff
D5 = 0xff
D6 = 0xff
D7 = 0xff
bv = outpc.boostduty * 10; /* convert 0-100 to 0-1000 */
data[0] = bv & 0xff;
data[1] = bv >> 8;
data[2] = 0x01;
data[3] = 0xff;
data[4] = 0xff;
data[5] = 0xff;
data[6] = 0xff;
data[7] = 0xff;
send_can29bit(0x0cffc600, data, 8);
Re: HE351VE turbo CAN broadcast in pre-1.5 alpha 4
i'll try to compare the can bus signals this weekend
33 psi boost on lpg
having problems sniffing the can bus but have help coming.
33 psi boost on lpg
