Hello Friends,
I want to ask you a question. X and y spark settings available in version 1.2.4. But not in version 1.4.0. What is the reason of this ? I want to run E46 M3 indicator using the CANbus system. I make changes to the source code for it. But I did not like the 1.4.0 version of the rev limiter. herefore I need the source code for version 1.2.4.
Thanks for your understanding.
Best Regards
I need. "MS3 1.2.4 source code released"
Re: I need. "MS3 1.2.4 source code released"
1.4.x to version x and y min rev limiter feature can be added?
The user adjustable cut X from Y concept was removed as it caused confusion for most customers, so there are no plans to re-add it.
There are a number of options available for the launch cut limiter including two built in cut X from Y patterns.
Helle James,
Thank you for the answer. Donation software if I do x and y rev limiter can you add ? Or e46 m3 gauge for development 1.2.4 Do you share the source code?
Best Regards.
Best Regards.
I'm not going to add X/Y.
I will however make the old source code available.
Thank you, James. I look forward to sharing the old source code.
Best Regards
Best Regards
