Hi all,
Does anyone know the current state of supporting the VVTL-i on the 2ZZ-GE engine?
It's not the most straight forward system.
Toyota 2ZZ-GE VVTL-i Support?
Re: Toyota 2ZZ-GE VVTL-i Support?
It looks like the lift may be open loop, so no problems there.
Any info on the crank+cam teeth?
The man behind MS Labs
Yeah, lift is just switched on/off. There is no positional feedback.
The single cam variable valve timing needs closed-loop control.
The crank is 36-2.
Im not sure about the cam yet. It does have 3 teeth, but im not sure what spacing those teeth have.
The crank is 36-2.
IIRC, current code has the four cylinder patter. Use 2JZ-VVTi spark mode.
