Then I want to do an other make and now I'm able to compile but I always get this error in my ms3.ini file line 448: Binary file core.ini matches
I tried make clean, change nothing.
I tried to extract original ms3-source.1.4.0 and start from scratch I'm still getting this error.
I'm building on windows.
Any idea what is happening and why this appear in my ini file?
Here is the output of my compilation:
Code: Select all
$ make ms3pro
/bin/echo "// setup for MS3PRO" > opt.h
/bin/echo "#define MS3PRO 1" >> opt.h
grep -v "^#[02345]" core.ini | sed 's/^#1//' > ms3pro.ini
/bin/echo "; DO NOT EDIT - this file is automatically generated during build" > ms3h_defines.inc
grep "^#define" ms3_vars.h | awk '{print ".equ",$2,",",$3};' >> ms3h_defines.inc
grep "^#define" opt.h | awk '{print ".equ",$2,",",$3};' >> ms3h_defines.inc
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -O -fomit-frame-pointer -m9s12xg -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mxgate,--xgate-ramoffset -c xgate.s
/bin/echo "/* DO NOT EDIT - this file is automatically generated during build */" > ms3_main_vars.h
cat ms3_vars.h | sed 's/extern //' | grep -v "^#" >> ms3_main_vars.h
/bin/echo "/* DO NOT EDIT - this file is automatically generated during build */" > ms3_defines.h
grep "^#define" ms3_vars.h >> ms3_defines.h
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_can.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_can_isr.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_ego.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_ign.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_ign_wheel.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_main.c
/tmp/cc5UMoP4.s: Assembler messages:
/tmp/cc5UMoP4.s:17419: Warning: ignoring changed section attributes for .text
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_misc.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_boost.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c premain.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_init.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c sigs.c
/tmp/ccnwAAQL.s: Assembler messages:
/tmp/ccnwAAQL.s:19: Warning: ignoring changed section attributes for .text
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_ign_in.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_inj.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_idle.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_user.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c sd_card.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c compress.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_pid.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c serial.c
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_conferr.s
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_burnfactor.s
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c isr_sci.s
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c isr_rtc.s
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c ms3_asm.s
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c isr_timerovf.s
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c isr_ign.s
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c xg_conf.s
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c isr_spi.s
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c isr_pit.s
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c compress-asm.s
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c crc32.s
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -c interp.s
c:/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m9s12x -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -Wa,-mm9s12x -Wl,-defsym,vectors_addr=0xff10,-m,m68hc12elfb,-T,m68hc12elfb.x -Wl,--no-warn-mismatch -o ms3.elf xgate.o ms3_can.o ms3_can_isr.o ms3_ego.o ms3_ign.o ms3_ign_wheel.o ms3_main.o ms3_misc.o ms3_boost.o premain.o ms3_init.o sigs.o ms3_ign_in.o ms3_inj.o ms3_idle.o ms3_user.o sd_card.o compress.o ms3_pid.o serial.o ms3_conferr.o ms3_burnfactor.o isr_sci.o isr_rtc.o ms3_asm.o isr_timerovf.o isr_ign.o xg_conf.o isr_spi.o isr_pit.o compress-asm.o crc32.o interp.o
ms3_main.o: In function `main':
/cygdrive/c/ms3/ms3-ricoboost-1.4.0/ricoboost/ms3/ms3_main.c:585: warning: banked address [e0:8800] (390800) is not in the same bank as current banked address [fe:b298] (40b298)
/cygdrive/c/ms3/ms3-ricoboost-1.4.0/ricoboost/ms3/ms3_main.c:587: warning: banked address [e0:8800] (390800) is not in the same bank as current banked address [fe:b2a7] (40b2a7)
/cygdrive/c/ms3/ms3-ricoboost-1.4.0/ricoboost/ms3/ms3_main.c:589: warning: banked address [e0:8800] (390800) is not in the same bank as current banked address [fe:b2af] (40b2af)
ms3_init.o: In function `main_init':
/cygdrive/c/ms3/ms3-ricoboost-1.4.0/ricoboost/ms3/ms3_init.c:3000: warning: banked address [e0:8800] (390800) is not in the same bank as current banked address [f8:a328] (3f2328)
c:/usr/bin/m68hc11-elf-objcopy --output-target=srec --only-section=.rodata --change-section-lma .rodata=0x7fea00 --only-section=.cnfdata --change-section-lma .cnfdata=0x100000 --only-section=.cnfdata2 --change-section-lma .cnfdata2=0x103000 --only-section=.cnfdata3 --change-section-lma .cnfdata3=0x106800 --only-section=.lookup --change-section-lma .lookup=0x104000 --only-section=.texte0 --change-section-lma .texte0=0x780000 --only-section=.textf0 --change-section-lma .textf0=0x7c0000 --only-section=.textf1 --change-section-lma .textf1=0x7c4000 --only-section=.textf2 --change-section-lma .textf2=0x7c8000 --only-section=.textf3 --change-section-lma .textf3=0x7cc000 --only-section=.textf4 --change-section-lma .textf4=0x7d0000 --only-section=.textf5 --change-section-lma .textf5=0x7d4000 --only-section=.textf6 --change-section-lma .textf6=0x7d8000 --only-section=.textf7 --change-section-lma .textf7=0x7dc000 --only-section=.textf8 --change-section-lma .textf8=0x7e0000 --only-section=.textf9 --change-section-lma .textf9=0x7e4000 --only-section=.textfa --change-section-lma .textfa=0x7e8000 --only-section=.textfb --change-section-lma .textfb=0x7ec000 --only-section=.textfc --change-section-lma .textfc=0x7f0000 --only-section=.text3 --change-section-lma .text3=0x7f4000 --only-section=.textfe --change-section-lma .textfe=0x7f8000 --only-section=.text --change-section-lma .text=0x7fc000 --only-section=.vectors --change-section-lma .vectors=0x7fef10 ms3.elf ms3pro.s19
grep Format sigs.c | sed -e 's/.*MS3/QMS3/' | sed -e 's/\".*//' >> ms3pro.s19
cat s19tail.inc >> ms3pro.s19
