I'm interested in measuring my turbos compressor wheel speed during different driving conditions. I've found several optical speed sensor pick ups from a few places. Most put out a simple raising/falling edge signal at 1 pulse per Rev. Triggered off of that white paint mark on one fin. I assume there would need to be some sort of scaler of 1to100 or so. 1000 would really equal 100,000 rpm.. any ideas?
VSS input to measure turbo speed
Re: VSS input to measure turbo speed
why not use the generic shaft speed for this, http://www.msextra.com/doc/pdf/html/Meg ... 4-226.html
Yep, we're using this on our 240SX land speed car.grom_e30 wrote:why not use the generic shaft speed for this, http://www.msextra.com/doc/pdf/html/Meg ... 4-226.html
I'm using the generic shaft speed too on my HE351VE with 1 pulse per rev.
Cool, got it. That's nice.
What is the max speed for the "High Speed" input
