Need delay between nitrous and fuel/ign retard
Reverant
Post by Reverant »
On the track and having an issue with the nitrous.
The solenoid is in the passenger side footwell, so there's quite a bit of distance between the solenoid and the engine.
When I'm giving less than 50% duty on the valve, there's a delay between activating the valve and the nitrous reaching the cylinders, and the engine bogs down as fuel is added and timing is retarded instantly.
So, I need an additional delay before the fuel/timing is adjusted - activate the solenoid now, and add fuel/retard the timing 100ms later for example.
Easy and makes sense, right?
The man behind MS Labs
