this type of cas is used in usdm nissan cars. this cars run fully sequential injection. there are in nissans from 89-2000 using 4 cylinder engines. 6 cylinder cas are similar.
4 cylinder engines obd1
- sr16de usdm
- sr20de usdm
- ka24e usdm
- ka24de usdm
- ga16de usdm
those 5 engines runs a lot of cars in nissan market using obd1 and obd2 ecm´s. they run distributor. no coil on plug. no crank sensor in crankshaft. optical sensor in distributor.
already ms3 support only jdm cas for sr20de(t) and rb2xde(t) only.
thankyou for your time and hope we can run fully sequential using stock cas for usdm engines.
feature request : nissan cas compatibility (usdm)
Re: feature request : nissan cas compatibility (usdm)
That's already in the long-term TODO list. However, these CASes can be used now in "Basic Trigger" mode to give the single coil output and run batch fire fuel.
