Crystal Controlled RTC
TURBOSNAKE
Post by TURBOSNAKE »
James,
I've been having problems with my RTC (see post in general support section), and I recently came across a very small board with a clock and battery on it that's about the same size as the one I bought with my kit, but this one is crystal controlled and costs less than $5. It's a Tiny RTC from I2C Modules, and has the following connections: SQ, DS,SCL, SDA, VCC,GND and BATT.
At first glance, this seems like a less expensive and more accurate arrangement, but I'm wondering if you think it will work with the firmware (1.41).
Regards,
Jim
TURBOSNAKE
Re: Crystal Controlled RTC
James, Here's a link to the data on the Tiny RTC: https://www.elecrow.com/wiki/index.php?title=Tiny_RTC
Jim
AbatelliCristian
Post by AbatelliCristian »
It depends on the chip used. They are not all compatible
Post by racingmini_mtl »
The MS3 RTC does have a crystal. And make sure you do use a fresh battery.
As Jean says, the realtime clock is crystal controlled already. If you elect to use a different chip, you'll likely need to write new firmware to support it as it is very unlikely to have the same I2
