Hi James,
I am currently trying to get my ms3extra to drive a 350z dash in a 240z using CAN. Hoping I posted this in the right spot.
Could anyone help? is any special code require? or is it front end config on the latest version?
Has anyone done it and can provide what i need to do it.
I believe it is only the tacho and temp that is required, all the test is covered.
350z can bus
Re: 350z can bus
There's an option to broadcast coolant temp and RPM. I'm not sure if anyone has tested it.
Re: 350z can bus
So its all working now, Temp and RPM. All the rest is mostly low level so great and thanks.
Solution was to download the latest alpha firmware and turn on rpm and temp for 350z.
Megasquirt is gr8
Thanks!
Megasquirt is gr8
Thanks!
Re: 350z can bus
Excellent! To help document this for future users, can you post a copy of the MSQ so we can see the settings you used?
Re: 350z can bus
Sorry,
Havent' been on for a while. Here is the MSQ
6.3 litre twin turbo V8 sbc
- Attachments
- 2018-04-05_08.30.58.msq
- (274.29 KiB) Downloaded 29 times
