IAC as boost control
Is It in the plans to control a turbo with a stepper motor?
Re: IAC as boost control
I offer a PWM to Stepper controller that will use the PWM boost control signal to drive a 4- or 6-wire stepper motor. I have to ask, though, how does that work? Is it like an idle valve, with the pintle opening and closing to control the boost?
I think he may be referring to a variable geometry turbo having the vanes controlled by the stepper motor.
If not disregard.
Sent from my SM-G900V using Tapatalk
If not disregard.
Megasquirt 2 V3.0 Running Msextra 3.4.2. in a 1989 Camaro RS .48AR/60mm Turbo 3.4L/700R4
Boost control, Fan control, Stepper IAC, Launch/Antilag, Working on the GMDIS, and Methanol injection
There are also vehicles out there with electronically controlled waste gates. Hyundai Genesis coupe with a 2.0T for sure and I imagine there are others.
Support the developers!
