Feature request: Boost by gears target switching
Hi! Very need boost by gears with target switching. So I will run low boost by gears in city and hi boost by gears in race mode. Thanks!
BMW 525i, stroker 2.8L, MS3-Pro 1.4.1, BIPs 373, 66mm turbo 30 psi
Re: Feature request: Boost by gears table switching
Already in there. Not table switching, but boost by gear is already a feature.
-MS3X, (V3 PCB) 1.2 RC 1 firmware. Controlling a light modified Audi 1.8TQ AEB 20v engine with Holset HE221W turbo, 299.4 HP and 400Nm at the hubs in Dynapack.
If I understand it correctly, he needs 2 sets of boost by gear targets, and needs to be able to switch between those sets ie with a switch.
The man behind MS Labs
Loop function or Blend table would work for boost switching by gear.
2000 Suzuki Hayabusa turbo MS3 beta testing Plug and Play standalone
http://interfacepnp.webs.com/
http://www.youtube.com/Busams
Yes you are right.Reverant wrote:If I understand it correctly, he needs 2 sets of boost by gear targets, and needs to be able to switch between those sets ie with a switch.
Not working with Boost by gears setup.turbo355 wrote:Loop function or Blend table would work for boost switching by gear.
Firstly when I stacked with this problem was shocked - so powerful ECU didn't get ability to switch boost by gears targets for street and race purposes.
Would be cool to have a boost by gear dual table option. I would use this on my street car
